December 31, 2024, 09:52:55 PM
[Today at 08:49:53 PM]
[December 28, 2024, 09:26:24 PM]
[December 28, 2024, 01:42:55 PM]
Topic: Downrigger Mount on a Native Slayer Propel 13  (Read 3599 times)
rustyski
  • Date Registered: Jun 2015
Hi all,
I am looking to install a downrigger on my native slayer propel.   I have a scotty laketroller, and I have a scotty mounting bracket for it attached to some mightymounts in the rail system, but I find that trying to troll with it in the salt is really challenging, as it only has a 4lb ball and the blowback on it is insane.  I want to upgrade to a depthmaster, or some other similar compact downrigger that will be able to handle a heavier ball, while still being able to mount it to the rail system.  Any thoughts?  I have seen people mount them on hobies numerous ways, but nothing on a slayer.  Mostly, I want to find a way where I could affix a mounting plate in the rail system so that it spreads some of the stress out over the rail, without limiting pedaling ability.
Boats:
2019 Hobie Outback
Event Finishes:
2020 AOTY 5th Place
2020 Tiny Fish Slam Winner
2019 Tiny Fish Slam 2nd
The rail system on my older slayer in my opinion is not strong enough to handle the stress. I’d consider a plate on the inside of the hull to get a firmer grip.
rustyski
Mine is a 2013.
Boats:
2019 Hobie Outback
Event Finishes:
2020 AOTY 5th Place
RoxnDox
  • Native Propel
  • Date Registered: Sep 2013
Hey Rustyski, if you do the Farcebook thing there’s a Native owners group where they talk a lot about gear and modding out the boats (https://www.facebook.com/groups/slayerpropel/?ref=share)...
Mine is a 2016, I would also recommend a backing plate under the rails.
rustyski
Sent a request to the admins to join the fb group. Thanks!
Boats:
2019 Hobie Outback
Event Finishes:
2020 AOTY 5th Place
Mine is a 2013.
Mines a 15 the railed move around a lot just from my salmon trolling rod!
rustyski
I know on mine the rails don't have screws in all of the attachment points stock.  Have you screwed down each attachment point on the rail? It may give it added support.
Boats:
2019 Hobie Outback
Event Finishes:
2020 AOTY 5th Place
No, I’m thinking about trying to see if I can get some kind of backer behind it.
rustyski
I stumbled across this, and it seemed like a really nice solution to the mounting problem.  Not sure it will save me any money but if I can get a cheap lever drag reel, I may be in business.
Boats:
2019 Hobie Outback
Event Finishes:
2020 AOTY 5th Place
rustyski
Another thought I had. Do you think a scotty gimbal mount would work? The Slayer has a 30 degree pole holder just to the right of the seat. My concern would be it being too close to the seat and having issues cranking up the cable, but it could work.
Boats:
2019 Hobie Outback
Event Finishes:
2020 AOTY 5th Place
conquestdz
  • Date Registered: Jan 2019
You need to get 3 dimensional to spread the load out.  What holds that handle on the outside?  Maybe you can come up with an L shaped mount that used the rod holder and the screws holes for the handle.  That would be solid as a rock and spread the load well.
