June 26, 2024, 07:49:01 AM
[June 25, 2024, 08:26:02 AM]
[June 24, 2024, 01:51:03 PM]
[June 24, 2024, 01:01:07 PM]
[June 21, 2024, 11:43:01 PM]
[June 20, 2024, 05:54:41 PM]
[June 18, 2024, 12:17:27 PM]
[June 18, 2024, 06:26:16 AM]
[June 17, 2024, 11:39:39 AM]
[June 13, 2024, 08:15:37 AM]
[June 12, 2024, 01:01:01 PM]
[June 10, 2024, 11:17:34 PM]
[June 10, 2024, 07:16:15 PM]
[June 10, 2024, 12:39:16 PM]
[June 08, 2024, 06:29:12 AM]
by Spot
[June 07, 2024, 11:10:55 AM]
Topic: Furling  (Read 6030 times)
I will be rigging my new Revo soon. I'm planning on doing the geatrax in the usual spots on both sides of the gunwale for mounting ff and rod holder. I would like to consider adding a sail and furling kit in the near future. Looking at how the factory furling fairlead and ropes go, I'm wondering if there will be room for both. Any advice?
<Proverbs>
Low_Sky
I have no first-hand experience with this, but I have been doing the same research you have been doing regarding sailing my new Revo 16.  The most useful nugget of wisdom I have found on this is that the Hobie-recommended placement of the furling line fairlead is not exact.  It will obviously vary from boat to boat, and can also be re-positioned as needed to clear other gear on your boat.  I believe I gleaned that from Matt Miller on the Hobie Forum.  Hobie has to prescribe a location in the installation instructions because some people are so mechanically dis-inclined that they would be lost without guidance.
2016 Hobie Revolution 16
2014 Perception Triumph 13
Well, I guess ill find out. I see no reason why I cant mount the fairlead on the geartrax. Ill make a little spacer to mount it on a 45' angle. That should make it adjustable fore and aft, but the rope coming back may interfere with the fish finder. Ironically someone had just posted about this on the Hobie forum: http://www.hobiecat.com/forums/viewtopic.php?f=32&t=57189
I am considering using Yakataks new anchor trolley system components along the side to improve functionality, aesthetics and keep it all tidy. Surely I'm not the first person to have thought of this.
<Proverbs>
Rigging a new Hobie Revolution 13 with a rollerized sail and furling kit on Gear Tracks.
Although the factory Hobie sailing and furling setup is simple and works, I felt there is a lot left to be desired. I’m upgrading from the factory Hobie hardware to a rollerized pulley system and mounting on modern Yak-Attack GT90 Gear Tracks. I can’t take credit for many of the ideas contained in this article as much of this has been scavenged from around the internet in different applications.
1)   Tie downs- I have drilled a hole in the center of all 5 of the threaded tankwell bungee cleats and installed ¼-20 stainless eyebolts with a washer and nylon nut.
2)   Furling Kit- The furler is designed to roll up the sail on the mast so you have control of when and how much sail you want to deploy. One association that I made rather quickly was the fact that the furling system shares much of the same concept and needs as an anchor trolley system. So why wouldn’t you want it on rollerized pulleys?
     a)   Fairlead- The factory Hobie fairlead that comes in the furling kit is just a small double cleat that is supposed to be mounted (permanent) at a 45’ on the gunwale near the mast. This is in a very bad place when using gear tracks and is not easily mounted on gear tracks. I have mounted two Harken 29 Carbo Cheek pulleys on a Yak-Attack JK Hatch Accessory Plate to the forward gear tracks. This keeps the ropes outboard of the hull and away from the rod holder or whatever else gets mounted on the gear tracks. The rope stays alongside the hull, tidy and out of the way! All is good here!
     b)   The furling rope- By design, the Hobie factory set-up is supposed to just slide through a ring on a bungee at the rear. Again, why wouldn’t you want this on a pulley? I have simply added a Harken Carbo 29 pulley here. Much smoother operation!
     c)   The furler tension bungee- The hook of the bungee cord is supposed to be attached to a supplied pad eye that is installed at a location somewhere alongside the hull.  In my case, the bungee attaches perfectly to the added forward tank well cleat eyebolt. That’s 2 less holes to drill in my boat!
3)   Sidekick Ama Mounting- The factory Hobie install uses two 3/8” well nuts per side to mount the sidekick AMA cross bar. I'm not fond of well nuts to begin with, and the bar becomes "permanent". Therefore, I’ve chosen to mount the Sidekick Amas on Yak-Attack 8” GT90 Gear tracks with backing plates.
     a)   GT90 Gear Track Mounting- Nothing special about mounting your typical Gear Tracks, but in this case there are a couple things of consideration. The narrower GT90s are necessary because of the available width of the gunwale mounting surface on a Revo. Secondly the mounting location prevents you from being able to reach inside the hull for backing washers and nuts or use of Full-Backs, etc. The GT90 backing plates fit perfectly, but about the only way you can get them there is by “Fishing” them in there- such as done with the use of Yak-Attack (small 8-32) Rigging Bullets. Highly misunderstood, Rigging Bullets, are not mounting hardware at all but rather used as a tool!  And what a handy tool those are!
     b)   Hobie Sideckick Ama Gear Track Adapters- Yak-Attack has the adapters to attach the Sidekick cross bar with a T-bolt and Nut for the Gear Track Mounting. Easy on and off, and no big 3/8” holes to worry about later. Easy peasy.
4)     Main Sail Line- The main sail line is supposed to just go through the rear padeye (same one the carry handle is on) and the main sail line is just to be held in hand by the captain. Not very elegant, and a lot of loose rope!
     a)   I have added Harken 29 Carbo pulley on a  at the rear pad eye. Less friction, and much smoother!
     b)   The main sail line routes back to the pulley, and through the starboard side tank well through the tie downs SS eyebolts that I have added. Nice and tidy!
     c)   Just forward of the starboard Sideckick Ama mount goes a Spinlock PXR Cam Cleat to lock and control the main sail line. This is the item I would prefer to track mount. All I need is track nuts with 8-32 threads. The standard ¼-20 fasteners are too big to fit.  So far, I have been unable to find 8-32 track nuts, so I will make my own in the near future. Ironically the devise bolt pattern fits exactly in line with the GT90 button head fastener spacing! I just used longer 8-32 stainless countersunk head screws, but this makes the mount somewhat “permanent”. This bugger is kind of spendy, but is a SWEET devise for this purpose!
Parts as follows:
Eyebolts- http://www.amazon.com/Hillman-Group-4289-Stainless-5-Pack/dp/B00IAVMG8U?ie=UTF8&psc=1&redirect=true&ref_=od_aui_detailpages00
SS Washers http://www.amazon.com/Hillman-Group-830502-Stainless-100-Pack/dp/B00CAG22C6?ie=UTF8&psc=1&redirect=true&ref_=od_aui_detailpages00
SS Nylon Nut- http://www.amazon.com/Hillman-Group-829720-20-Inch-Stainless/dp/B000B4GU0Y?ie=UTF8&psc=1&redirect=true&ref_=od_aui_detailpages00
Harken Carbo 29 pulley- http://www.westmarine.com/buy/harken--29mm-carbo-air-single-block--2042158
Harken 29 Carbo Cheek pulleys- http://www.westmarine.com/buy/harken--29mm-carbo-air-cheek-block--2042331
Yak-Attack JK Hatch Accessory Plate- http://www.yakattack.us/AAP_1022_p/aap-1022.htm
Yak-Attack 8” GT90 Gear tracks- http://www.yakattack.us/GT90_08_p/gt90-08.htm
GT90 backing plates- http://www.yakattack.us/FB_GT90_08_p/fb-gt90-08.htm
Yak-Attack (small 8-32) Rigging Bullets- http://www.yakattack.us/RB0832_p/rb0832.htm
Hobie Sideckick Ama Gear Track Adapters http://www.yakattack.us/TBK_1001_p/tbk-1001.htm
SS carabineer-SS carabiner http://www.westmarine.com/buy/suncor--stainless-steel-carabiners-without-eye--P002_060_002_500
Spinlock PXR Cam Cleathttp://www.westmarine.com/buy/spinlock--pxr-camcleats--P002_064_002_524
I'm sure there's some Hobie sailors that would like something like this. I would also like to state for the record, I am not “PRO-Staff” or sponsored by anyone, nor have I received any promotional items for this write-up.
<Proverbs>
shougaler
Thanks for doing this write up and posting pictures. I've been working on adding a similar mod. for my furler kit. I saw a great video that someone did on this on YouTube... but it was in German. So I find your parts list and directions very Germaine to the task at hand. Thanks!
RoxnDox
  • Native Propel
  • Date Registered: Sep 2013
That's a slick-looking rig...  How does it sail?
Dunno yet! I did get out to try it, but that was before I got the Sidekick Amas on. Check it out here:
<Proverbs>
I have replaced the cleats around the rear cargo area of my Revolution with Hobie screw-in padeyes. http://www.austinkayak.com/products/872/Hobie-Mirage-Screw-In-Pad-Eye.html . Could you have used these screw-in padeyes for tie-downs rather than stainless eyebolts?
Yes. And I considered this, but you loose the ability to quickly release the cargo bungee with those eyes.
<Proverbs>
I don't use the long criss-cross bungie which comes with Revolutions to hold gear in my cargo area.  I use individual bungies with hooks and nylon straps with mini carabiners.
shougaler
Hey anyone have any ideas on some tubing to use on the crossbar that comes with Ama kit. I have an Oasis, and I put some Ram mounts were the crossbar should be mounted. I can remove the mounts and refill the holes and put the gear track on with the YakAttack mounts, or I could possibly put the crossbar behind the front seat. This looks to work nicely, but the crossbar is too short. I bought some 6061 tubing that I am milling to make my own crossbar for that location. Any better ideas?
Ill bet you could just use some EMT conduit. Measure or take an ama arm to the hardware store to see what will fit. Might have to buy a 10 foot piece though.
<Proverbs>
shougaler
I'll give that a try. I have combed most of the aisles at Home Depot, even as far as considering handles for mops/brooms. I did find Metal Supermarket over by Costco off Airport Way (PDX). I bought some Aluminum 6061 tubing. However the Hobie crossbar is an odd size. So I will do a little reaming, a little drilling, and we'll be good.
Low_Sky
Browneyesvictim, great write-up. If I ever sail my Revo16, I'll be doing something very similar.  As for why the Hobie kit doesn't do it "right".... Cost. A cast double cleat and a plastic ring are a lot cheaper than pulleys.
Pete, what's involved with installing the screw-in eye pads?  Drill the right-sized hole and you're done?  More than that?
« Last Edit: September 29, 2016, 01:51:14 AM by Tinker »
Everything will be all right in the end, so if it's not all right, then it's not yet the end.
