February 04, 2025, 07:55:24 PM
[Today at 09:09:22 AM]
by Shad
[January 29, 2025, 01:17:44 PM]
by PNW
by Spot
Topic: Hummingbird "Fishing Buddy" Mount?  (Read 25206 times)
FLYRODR
  • Date Registered: Nov 2007
Been trying to brainstorm a method of mounting my fishfinder but only experiencing minor "squalls..."  I've got a Hobie Outback and am wondering if anyone out there might have some pics of their personal mounts.  If there's a manufactured mount that can be modified, I'd love to hear about it!  Thanks!
"FLYFISH FOREVER"
I think CoosBayYakker has made his own version of the Humminbird Fishing Buddy out of some PVC and an Eagle Cuda fish finder.  He has it mounted in the cup holder of his Outback.
http://www.northwestkayakanglers.com/index.php/topic,809.0.html
Most people however, use a more permanent mount with a regular non-portable fish finder.  Hint:  the transducer itself doesn't need to be in the water and can actually be mounted inside your kayaks hull and can "shoot through" the plastic of your kayak.  A quick search for 'transducer' on this site should yield more specifics on what I'm talking about.
FLYRODR
I decided on the "Fishing Buddy" since I transfer it to my pontoon boat an awful lot.  I'm not certain its design allows for through-the-hull use.  The transducer is in the stem of the unit and most likely needs to be suspended in the water.  I just heard about RAM Mounts and will browse the web on these but would like to see any homemade mounts for this particular unit if anyone's so willing.  BTW, I'm kinda new to the site, been a hardcore fly guy for 40 years and bought my yak as a retirement gift a couple of years ago.  The best purchase I've ever made!  Now when the wife tells me to go exercise, I grab my gear and go fishing!
"FLYFISH FOREVER"
I don't know of anyone here that actually uses the Fishing Buddy, but I'm sure you could do like Coosbayyaker and wedge something in our cupholder.  As long as it had a large ridge that the Fishing Buddy Clamp could easily attach it should work.
I believe Pisco Sicko actually has one of these for his rowboat. So what's your 2 cents PS?
I was wondering if you could just drop the transducer stick down through a scupper hole?
I do have a hand-me-down Fishin' Buddy, that I used for 2 years, until the transducer apparently gave up the ghost. Easy to use on the rowboat, as I just used the unit's clamp-mount to clamp to the rowboat rail. The previous owner cut the "stem" of the unit down to be able to shoot thru a scupper hole. I don't know how well that worked for him, since he ended up giving away the unit. ???
I've since updated it with smaller diameter PVC and and a pivoting leg to kick up out of the water to lessen drag for travelling or if it hits someting in the water. I turned the plug that fits tight in the cup holder on my lathe. The cable and batteries go in the grey box. The finder swivels too..
kallitype
  • Vashon Island kayaker
Verry slick!!  Now, to find that tide info...mebbe Fido knows something???
FLYRODR
That was a nice set-up for your Hummingbird.  Unfortunately, I have the one-piece that has the transducer mounted at the base of the stem.  I couldn't use a scupper hole anyway; when fishing, I reverse my Mirage Drive and that allows me to properly troll backwards.  I'll keep plugging away at it...  thanks for all the replies.
"FLYFISH FOREVER"
yessnoo
  • Date Registered: Apr 2008
i was reading on the humminbird website and if i remember correctly....humminbird gps units actually have the same tide and current information....if i understand correctly they are generated from goverment tide and current buoys so the T and the C your seeing and clicking on are actually Buoys.....i think lol....the instruction manual i was reading didn't say that exactly but it did say tide buoy....that was on the navionics software which is compatible with almost all brands of fishfinders though not standard on humminbird but is an upgradeable option...
as for map create which i think is the standard on the eagle but not sure....anybody know?
i had map create version 6 on my Lowrance handheld H20 so again a program that is compatible with many brands of gps....i can't remember if it had tides or not because i used when i was mostly in freshwater on my dads pb but i think it had the same thing
Hmm, OK I'll bite..I've never trolled backward, not even improperly.   ???
« Last Edit: September 28, 2008, 10:18:44 PM by coosbayyaker »
yessnoo
ya i was wonderin about that one too lol
bjoakland
  • Piscis Venator
I've heard of this done from quite a few people in different applications. Simply you put the drive in backwards from the regular way. This way the fins are facing the opposite direction so when you pedal you go in reverse. I've heard of some bassers using this technique to pull bass out of heavy cover and some also backtrolling in light current. Like I said I've yet to try any such techniques so can't give any exact details but I doubt I'd use it anyway. Let's give it a try and see what happens!
