December 26, 2024, 01:21:58 PM
by Spot
by Spot
Topic: Is the Hobie Bimini worth it?  (Read 3696 times)
SFHarry
It isn't but it does float! I also bring my Tamron 150-600 with me occasionally in my bigger Pelican case. I usually have a waterproof Lumix DMC-TS5 for quick shots. Other devices sometimes brought are a Mavic Mini drone and a GoPro 8 hat cam. I use a Cotton Carrier to keep the big Tammie under control when pedaling.
Hobie Outbacks 2019, 2012
DOA Humboldt Kayak Group 2012-2023
GS8, GS9, GSX, GS11, GS12, GS13
Rockfish Wars 2014, 2015, 2016
AKA: Hobie-Wan Kenobi
BigFishy
  • Date Registered: Nov 2020
I knew Pelican cases float but surprised that it will not sink with all the heavy camera gear. Something about that displacement physics law...
2021 Hobie Outback
tdspence
  • Date Registered: Apr 2021
The yellow box in the back is a Pelican case for my Nikon D7500 and 70-300mm Tamron lens. I use a Scotty Bazooka tube with the slip disc setup and a Costco golf umbrella that fits in the tube perfectly. The slip discs allow me to angle the umbrella any which way to block sun or catch some breeze. I leash the Umbrella cause it will sink in a flash if it gets loose.  Otherwise, the tubes make a great arm rest and trolling rod setup. I've hooked some 20lb lings and 27" Steelhead with this setup and it works a treat! If the wind is above 5-6 mph I don't deploy the umbrella, of course.
Thank you for the info. I like your setup and it is much cheaper than the Bimini. The wind usually is not bad where I go, so I not being able to use it occasionally won’t be a big deal. I will just keep the hat on and make sure to use lots of sunscreen.
2021 Hobie Outback
2020 Lifetime Tamarack
Pinstriper
  • Date Registered: May 2015
We have tried both an umbrella (mount clamps to the seat) as well as the actual Hobie Bimini. The umbrella constantly pulls over from the wind, and the bimini has multiple lines that would interfere with fishing, not to mention self rescue, and itself gets pushed around a lot from wind.
It is also frequently out of position to provide actual shade, unless you are pedaling straight into or out of the sun, at mid-day when it is high in the sky. Otherwise it comes in under the awning and you are in the sun anyway.
It makes a fine spinnaker when heading downwind, however.
Not recommendable.
Let's eat, Grandma !
Let's eat Grandma !
Punctuation. It saves lives.
SD2OR
  • Date Registered: Jul 2020
When I bought my first Outback (used), many years ago, it came with a kayak shade. I forget the brand name, have never seen one since. Anyway, when I first saw it, I thought it was the coolest thing ever. Then when I got ot on the water, I realized that it indeed was not. Its cords constantly got in the way, kept me from accessing things behind the seat, rarely cast shade on me, due to angle of the sun, impaired my ability to cast, and caught the wind way too much. After one trip, I got rid of it, and do fine with appropriate clothing, wide brim hat and sunscreen.
but why risk it?
3rd Place AOTY 2023
3rd Place ORC 2023
1st Place Team Event BCS 2023
2nd Place AOTY 2022
1st Place Tiny Fish Slam 2022
2007 Red Hobie Outback "Serenity"
SFHarry
I tried the clamp on umbrella type but sent it back for being to flimsy. My umbrella is a fairly sturdy setup and I can position it on either side and adjust it using the Scotty slip discs and pulling the Bazooka tube out to reposition. The umbrella was purchased at Costco and occasionally shows up there. I was extremely lucky the handle just fit the Bazooka tube, I don't know of any others that would work as well. It's a ShedRain model but I couldn't find it on their website, but did find it on an EBAY site for twice as much $.
« Last Edit: July 04, 2022, 09:34:53 AM by SFHarry »
snopro
Scotty slip disks are great.  Can't wrap my head around umbrella or bimini on a fishin yak being a good thing.
