October 17, 2026, 01:41:40 PM
[Today at 09:51:49 AM]
Topic: Kayak Repair Question - SOLVED  (Read 10020 times)
The kids are coming down soon, bringing a kayak with them to see if we - meaning me, I reckon - can fill in some holes left behind when they removed a Scotty mount.  From their description of the mount, it sounds like a Scotty 241 Surface Mount, and I believe the bolts for those are around 3/16-inch in diameter.
Would you recommend using a KC welder to melt the plastic into the holes?  Is there a reliable, less expensive tool - even the non-Hobie version runs $88 - that'll do the job?  Is there a better way to fill-in the holes than by using a welder and HDPE rods?
I expect to only do something like this once...
« Last Edit: July 16, 2023, 04:40:59 PM by Tinker »
kredden
  • Date Registered: Feb 2018
I use the Hobie one now that I work at a dealer but I've used this cheap Harbor Freight one in the past and it did OK for filling holes.
https://www.harborfreight.com/80-watt-iron-plastic-welding-kit-60662.html
Kevin
kaz
  • Date Registered: Oct 2018
I've linked a video of a guy using Swix P-Stiks to repair scratches in his Hobie. He doesn't use a welder; he just ignites the plastic rods and drips the liquified plastic into the scratches.   I've used this method to fill some screw holes in my Necky Dolphin14,  and after several months all is well. I had access to the underside of the holes so I backed the holes with a small square of heavy aluminum foil - held on with masking tape.  Good luck.
*Rods were purchased from Amazon - about $10.
Cape Falcon F1 (homemade, skin boat)
Trident 13
Necky Dolphin 14
Thank you, Kevin.  Sure, you guys at dealers get all the good stuff and the rest of we peasants have to settle for the Harbor Freight junk, but if it works, and I only need in once...  Thanks!
- Kevin
Kevin
Thank you.  I watched that video this morning and at first, I went "Eureka!" then I followed the link to Amazon and learned the P-Sticks aren't made with HDPE.  I'll check it out again since you've had luck with it.
Hey, since a Dolphin is on my list of kayaks-I'm-looking-for, but they're darned hard to learn about, would you tell me what you think of the one I've sent a link to in the PM I'm about to send?
I decided to go with plastic welding after I found I have a few scraps of the same color HDPE I saved when working on one of my kayaks.  I thought I'd trashed them, but I'm glad I didn't.
Thanks, everyone.  I appreciate the tips.
Why not just put screws or rivets in the holes with a touch of Goop?  Quick and easy.
Sure, now you chip in.
It's not my kayak - it belongs to a grandkid who wants me to "make it look pretty, again", although with my skills and a plastic welding tool in my hands, it could end up with screws and washers...
I've thought about using nylon screws and cutting the heads off flush then dabbing them with permanent markers.  I have more skill in matching colors than with welding.
Thank you, semi-INSAYN.  You're always a voice of reason and practicality.
