April 11, 2025, 02:50:39 PM
[Today at 01:03:22 PM]
[Today at 10:27:27 AM]
[Today at 09:36:15 AM]
[Today at 06:19:31 AM]
[April 07, 2025, 07:03:34 AM]
[April 05, 2025, 08:50:20 PM]
[March 31, 2025, 06:17:42 PM]
[March 29, 2025, 09:59:09 AM]
by Spot
[March 27, 2025, 04:01:04 PM]
by PNW
[March 27, 2025, 11:44:25 AM]
[March 12, 2025, 03:12:28 AM]
[March 11, 2025, 08:50:07 PM]
[March 06, 2025, 09:24:33 PM]
[March 06, 2025, 11:50:47 AM]
[March 01, 2025, 08:59:47 AM]
SD2OR with an early bucketmouth
Topic: King Salmon Spinning Rod  (Read 9151 times)
Kenai_guy
I'm looking to add to my arsenal of fishing rods..... 33 currently, and I'm thinking of adding a stout spin cast rod for catching kings and anything else it'll bring in.
Any suggestions on rods or reels?  Best length for yak fishing?
9th place 2014 ORC
I noticed your interest in down rigging. Kings are a prime target. I'd recommend a level wind or bait caster for that application.
Even trolling with flashers and such a reel you can thumb down on while deploying will make your life easier.
Kenai_guy
I've got 3 rods set up for that....just curious if there were any benefits for a spinning rod to fish kings with
9th place 2014 ORC
Mark Collett
  • Make It Happen
Life is short---live it tall.
CraigVM62
For me,  the only time that spinning gear has the advantage is if I need to cast very light weights.  Once I start tossing anything over about 1 ounce, and I can cast just as far with a bait caster.....   make that around 1.5 ounces if into a head wind  ;D
I dunno ... catching a king on a 10.5' float rod sure is fun!
ConeHeadMuddler
  • non-competitor
  • Smells like low tide
No benefit...
Unless you are baitcaster challenged, like I am. I swore off bait casters back in the mid-60's, when the $15 one I had kept getting birds' nests every time I tried to cast with it. Gave me a complex about 'em. So I use spinning reels for casting spinners, spoons, and jigs (under floats) to Kings.
I have landed many Kings in the 20-30# range, a 31# (weighed) and 37# (calculated) on my spinning gear. Reel used was a Penn Spinfisher 450ss that I bought in 1982. Best rod was one that matched the old Penn, a Fenwick 8' med action (for 3/8 oz to 1oz lures, or 8-20# line). Drag is still good on that reel, but the anti-reverse is failing. I just replaced that with a new Penn Sargus 4000, which has no reverse. the Fenwick rod is still good, but I have a cheaper Okuma MH 8'6" I just got that I might use in the future.
The one issue I have with spinning reels and Kings is that I don't like to ever cast anything heavier than 12# test mono on a spinning outfit, so I can't really put the wood to 'em, but have to let 'em run. On my jig rod, my leader is usually 12# test fluorocarbon, but I was using 30# braid for mainline, even though I hate using the stuff on spinning reels.
 I think I can go to 15# test with some relatively smaller diameter mono like P-Line CX premium (12# test is smaller diameter than 10# Maxima Ultragreen), and not hurt my casting distance too much (average weight spinner I use in the rivers is 3/8 oz, sometimes 1/2 oz, and rarely any heavier than 3/4 oz). I'll bet that with everything else being equal, I can cast farther with the 12# P-Line than I can with the 10# Ultragreen, and also farther with 15# P-line than 12# Ultragreen. So i'm ditching the Maxima for mainline use. I'll use up what I have for leaders.
But when trolling in the Bay or ocean for Kings, I always use my trusty Penn 209.  Same for trolling the lower rivers, in the tidal flux. In the rivers, I keep my spinning gear at ready, just in case I see something holding near the bank.
« Last Edit: January 31, 2012, 09:00:38 AM by ConeHeadMuddler »
ConeHeadMuddler
Kenai_guy
No benefit...
I too am baitcaster challenged.  It doesn't matter how hard I try, I always end up cursing a ton when I use one.  Thus, spinning rods are a mainstay in my fishing arsenal.  I just don't have one big enough for Kenai kings yet
9th place 2014 ORC
I just spent 3 weeks in the sun shore casting a Penn 750SSm on a 10' rod.  Loved it.  Could easily cast 1/2 oz up to 6 oz.  50# braid, never any issue.  I may start using my light weight spinning rig (Shimano Spheros SP4000FA) for all my kayak salmon casting, or pick up a bit stouter 550SSm and another rod.
Trolling and jigging I'll stick to a level wind.
750SSm sure is a heavy reel to be casting for salmon.  You'll love the 4000 class reel with braid.  That's about the right size ...
I second that ... my 4000 is my heavy spinning ... 2000 is my light. I did just pick up a 4500 for hopes of tuna this summer!
I took a Penn Fierce 4000 to Baja this winter and loved it.  Great reel for the money, no complaints, I will own more.
Yeah, it is! Twitching jigs sure is easier with a spinning reel as well. If casting for salmon I'll go for a spinning rod first. Berkley IM8's are nice and cheap-ish. Lami's Norwest Special is another good choice.
Kenai_guy
Alright....you convinced me....Going to the store today to grab one.  That'll make 34 fishing rods in the aresenal
9th place 2014 ORC
jgrady
  • Date Registered: Mar 2010
Only 34? I put together poles and reels like model airplanes. LOL I don't drink smoke or do drugs ..But Ive got a BAD fishing pole habit..I enjoy older vintage gear. but the way to get past bait casting is have a bunch to try till they are all birds nest and then use the spin reel..as for pole size,Long ,short,thin ,stout, big small,got them all still no fish on the board so what do I know.outsmarted by fish so far..
